injectors
Started by packers, June 02, 2009, 03:23:00 PM
packers
Hi any easy way to identify the type of injectors that you have fitted .engine not been starting without problems since i bought it seems to be over fueling but after 30 secs run fine. Had 65mm pulley fitted + ? jabasport chip . come to suspect has
had larger injectors too.  that do not match with chip . would appreciate any ideas
Max
Is there a part number on them mate?
there should be a Bosch part code on them, write it down and then check against this list to see the approx flow rate:
http://www.polog40.co.uk/article_injector_table.php
Standard ones are about 190cc if I remember correctly.  They are normally black but colour isn't really any indication of flow rate.
packers
thanks for information part no is 0280150721 which acording to chart is 200cc would this be enough to cause a problem given the small increase over standard ?
those are probably standard to be honest.  I'll check the part number on some old standard ones I've got knocking about at home when I get back from work.
