VW Polo G40 Cup or Super Coupe Regulations from 1990's
Started by Ian Johnson, December 19, 2016, 11:13:27 AM
Ian Johnson
As Title, does anyone have a copy of the Original G40 Cup or Super Coupe Race Regulations...........reason being I contacted Safety Devices to get a new Homologation sticker for my Cup Car Roll Cage but due to several ownership changes all documents relating to the VW Cup Race series car specs have been lost. So basically they won't supply me with one as the only current cage the W015 is not certified for racing although it is copied from the original Cup cage.
I need the information so i can obtain the ROPS Certificate from the MSA which will then allow me to get my car Competiotion Car log Booke (vehicle passport as it is now) to enable me to run the car in MSA Sprints/Hillclimbs.
I have applied to the FIA for the original Homologation papers from 1991 but as these have lapsed they are struggling to find them...........oh the joys of motorsport.
Any Help much appreciated.
G40supercharged
Hi,
I have hopefully attached the super coupe regs from 2005 if that is any use to you.
Nick
Ian Johnson
Brilliant thankyou.............just had a quick read through and it doesn't specify the cage details or homologation number. Just refers to the 'original build manual'.
You don't happen to have a copy of that do you also?
many thanks
G40supercharged
Ian Johnson
G40supercharged
Hi,
I found a paper copy of the super coupe technical regs from Feb 1998 at home. Unfortunately that doesn't have any useful info in either and just refers to the original kit as well. The stuff in the 2005 version I posted above looks to have been lifted directly from the 1998 one, so I think you will need the original docs from 1991 - 1993.
G40motorsport
All the Super Coupe reg's only ever refered to the kit, at least all the copies I ever had did when I raced in the Super Coupes.
Like you say you will need an original set of reg's. I Know of someone that may still have a copy, bit of a long shot but ill try & track him down.
G40motorsport
Ian Johnson
Many thanks for trying............my search continues
