Draining the fuel tank
Started by DaBigGinger, August 29, 2015, 09:40:45 PM
DaBigGinger
What's the best way to drain the fuel tank? I don't particularly fancy the hosepipe method...
boyzey
Id du hose pipe but if you dont need the tank punch a hole in lowest part
pettsy
I power up the lift pump and pump it out
kwijibo_coupe
Under the lower dash cover on the passenger side you'll find a red/yellow wire coming from a yellow plug. Find the side that goes to the back of the car and put power to that side of the plug. That will power both pumps and drain the tank easy.
DaBigGinger
