isv valve
Started by boyzey, August 19, 2015, 07:48:27 PM
boyzey
Nuther question haha. Is any body running a gt or g40 without the isv valve fitted ? Reson I ask is my dailey is a gt with a low idle speed and I am building a g40 engin and dont have a valve and the water pipe I have dosent have the bracket to mount one any experiance ?
I believe Robin used to run it disconnected.
If you do need the correct water pipe and ISV i have one ready to go, all bolted up still.
Robin
Yup i binned mine off and didn't run it.
Quote from: Robin on August 20, 2015, 12:47:01 PM
Used to idle really well didn't it?
boyzey
Oryt cheerz jezza I shal let you no on that thank you. But mine is a mk2 block with bolt on water pipe whats yours. And yoof is that a sarcastic really well haha. How did it tick over robin cheers for replys guys
randombadger69
Tap a plate and tack it onto the pipe.
Robin
Quote from: Yoof on August 20, 2015, 01:51:31 PM
Once warm yes.  ;D
ive got a couple of water pipes
boyzey
Ok cheers robin so it is does actualy do something then when cold starting. Might av to sorce one then just in case ey haha cheers guys. And cheers pete will let you no. Probs justvweld a bracket on my pipe as its all painted up :-) cheers do pete
