Best cam and injectors for py g60
Started by John-125, October 27, 2013, 10:04:07 PM
John-125
Gunna be running
1341bottom end
Gt inlet +bigger throttle body
4branch
R1 g60 charger 68mm pulley
Just wondering if anyone has had any experience with different cam and injectors and I'm guessing I'm gunna need a 1.5 bar map sensor aswell would be great if someone could help
You will need the bigger map sensor for sure.
probably the red injectors, 310 or 315cc i think. When i was going down the G60 route i was planning to stick with my schrick cam, 276 i think it is. A friend who owns a rallye said he has tried a few cams for the g60 engine and said the best was the schrick cam, i think thats 276 as well.
This was my list i had:
G60 charger
G60 mounting plate for G40
G60 outlet elbow
Induction kit/pipework
FMIC & Pipework
1.5 bar map sensor
5pk 68mm ribbed belt kit
Sytec 135 ltr/hour
Bigger injectors? 310cc
John-125
Ok thanks that's great not 100%yet what can I'm still gunna go for Dont want anything mental :/
polo classic
Stock head?
I would really recomend a ported head to get the flow up....
John-125
John-125
Bump
Any other suggestion anyone run a g40 with a g60 chager
PR23M3K
I use Catcams camshaft 267/281 with G60 green injectors but over 1,3 bar it is getting to lean so I am changing them into Volvo injectors 0-280-150-785 (~310 cc).
Before you decide which cam you use, read this topic http://www.g-laderseite.de/forum/viewtopic.php?t=2121&start=0
