1341 Map ?
Started by Etches, March 25, 2013, 08:04:20 PM
Etches
Right at the min I have my ecu with this PPP map
Map #G40008- 1341cc chip- As above with altered parameters to suit a 6psi boost switch replacing the standard G40 WOT switch, giving a smoother more progressive drive
I have some of the 320cc injectors so should I chuck those on now or leave the g60s on untill I get it live mapped by Andy and Yoof?
I will be running the engine in with around 8psi of boost for 1000km before winding it up to 15psi before getting it mapped.
Currently the spec matches the G40009 chip description without aquamist (my head has been worked but not BV).
Cheers guys
Etches
leave the g60s in as you need the map to suit the injectors, as the map is done on duty cycle not flow a 20% duty on a 250cc injector is less than 20% duty of a 330cc injector
