Aeromotive fuel pressure regulator
Started by Jezza-7, December 07, 2013, 11:49:48 AM
Selling a brand new FPR
Its an A1000 -6 one, was bought for £178 inc vat.
Im looking for £110 posted, have seen these retail (demon tweeks) for as much as £246!
Features include
Two -6 AN inlet/outlet ports and one -6 AN return port
Maintains stable fuel system pressure between 40-75 PSI for tuned flow rate flexibility up to 180 GPH (1,100 PPH)
Features a vacuum/boost compensating port for a supercharger, turbo, or intake manifold vacuum connection
Holds minimum fuel system pressure for 25 PSI for at least 20 minutes after pump shutdown
Compact design fits small engine compartments
Cheers!
samuel.cole
Yeah they can be. The Portuguese guys use them on the G40's.
You can also buy a gauge for this regulator to get the correct pressure just to let you know.
