New g40 oil pump
Started by gaz g40, December 21, 2012, 11:48:10 AM
gaz g40
As title anyone know of anywhere that stocks/sells g40 oil pumps? Doing an engine rebuild and there like hens teeth to find
i can get febi ones.  just ordered one +chain and a few bottom end gaskets for etches on ehre.
breadman
How much is a Febi pump and chain now Pete?
gaz g40
rough prices
big crank oil seal @ 7
head bolt @ £0.90 (normal polo ones)
pulley side oil seal  -same as cam@ £3.00
oil pump chain @ £10
sump gasket @ £5
oil pump @ £88
also forgot flywheel bolts!  £1.20
quality looks ok - but never used pump.  if you want gaz i can have one next to a new vag one for you to compare?
gaz g40
how many have you sold pete? does the quality look good enough for you to fit one?
none, i had one ages ago and it seemed pretty good..
