Gates powergrip HTD 1000 8m 20mm wide tooth belt needed urgently
Started by chase_g40, August 25, 2012, 07:23:48 PM
chase_g40
Hi there as above I'm in need of a tooth belt mine has sheared all the teeth of the belt and need another belt can't find them anywhere and was wondering if anyone had a spare lying about or a place which will stock them thanks
chase_g40
Yes like that do you know how strong they would be not used a Medway way belt before only used gates belts ?? And do you know how good the quality is ??
Wouldnt have a clue mate. I remember someone talking about them but they are usually a bit cheaper than the normal ones so not sure. Could always get 2 and then you got a spare, then you can see how long they last.
They're all pretty much to an industry standard, ISO whatever. Shouldn't be any problems/
