oil pressure problems
Started by chris2911, May 09, 2012, 11:15:32 AM
chris2911
has anyone experanced or know what the fault with my oil pressure
on tickover it has 1-2psi of oil pressure
at 3000 revs its got 30-35psi oil pressure
ive tryed then switch then decided to put a gauge on to find the readings above also the hydrolic tappets are noisey
any help would be appricated
thanks chris
New pump, used pump?
PRV on pumps can stick (usually causes high oil pressure) likewise springs can snap/bind etc causing the relif pressure to be much lower.
Pickup clean and free from crap (paint, sealant etc) and doesn't have any cracks in it, likwise the pump to gallery feed is clean and free from leaks/cracks.
Also is the gauge you're using to measure the pressure, what is it (known good?) also where are you taking the feed for it from?
chris2911
used pump
picking up pressure from sensor at charger feed
think ive sorted it,its the charger disconnected charger got 40 psi on tick over and 110 reving.
tried spare charger on and the low oil pressure has gone.
the must be a interal problem in the charger so off to jabba it goes
Send it to Pete- not Jabba!
Much better service, and he'll run it on his car to check it's 100% before returning it to you.
He actually replaces all the seals/bearings- which seems to be something on several Jabba 'serviced' chargers I've had, they've missed.
chris2911
what is standard oil pressure on a g on tick over.
mine has 7-8 psi of oil pressure on tickover cold and well over 1 bar when warm.
do they have oil pressure release valves on these engines
the pressure is lower when it's cold?!  That's unusual.  Perhaps a sign that the pump is unable to pump the thicker oil??
It should go right up to 100psi or thereabouts when first started from cold.  Then as it warms up, gradually drop and shouldn't really get less than 10psi at idle.
The relief valve is a pretty basic spring loaded affair, mine stuck shut once causing too much oil pressure when cold.
Quote from: chris2911 on June 10, 2012, 08:32:04 PM
Something is expanding once warm and closing up a tolerance, allowing oil pressure to build.
What the history of the base engine?
chris2911
yoof engine is a 110,000 miles and was looked after in previos life by a audi mechanic and steve pitt.
i bought i from a chap in nottingham
Okay, so no leaks externally?
chris2911
none its dry as a bone, im going to fit a oil pump or release valve this weekend.
