Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
51mm throttle body problem???
« previous
next »
Pages: [
1
Go Down
Author
Topic: 51mm throttle body problem??? (Read 2290 times)
on:
August 16, 2012, 04:40:47 pm »
I replaced my t-piece gasket and noticed this:
Is this normal???
Re: 51mm throttle body problem???
Reply #1 on:
August 16, 2012, 05:57:22 pm »
is what normal ??
cheys03
Reply #2 on:
August 16, 2012, 06:07:11 pm »
Do you mean the smaller hole? Is it on the same side as the idle screw, as it's probably the idle air port.
Reply #3 on:
August 16, 2012, 06:25:12 pm »
Yeah the small one is the one im on about. its on the same side as the electrical plug bit so it would be directly under the boost pipe.
I thought the big one was the idle screw as you can see the screw inside.
cheys03
Reply #4 on:
August 18, 2012, 10:06:23 am »
Maybe it's a manifold pressure reference (vacuum) hose feed?
Hard to tell without a spare tb for closer inspection. I hope it's that, because the alternative is troubling.
Reply #5 on:
August 18, 2012, 04:10:32 pm »
Anyone got a picture to compare?
vee-dub90
Reply #6 on:
August 18, 2012, 04:37:27 pm »
Daryl in the for sale section is selling a stock one.. would that be of any help?
Justin14100
Traders
Reply #7 on:
August 18, 2012, 06:15:09 pm »
Its the hole that the wide open throttle sensor screws go into, some break through - if they do they get a wick of sealant or chemical metalled over to cover it up.
RyanC
Reply #8 on:
August 19, 2012, 12:34:01 am »
mine dont have that just the idle screw hole
Administrators
The CV joint killer
Reply #9 on:
August 23, 2012, 10:05:32 am »
no it can happen when the throttle bodies are ported out to 51mm. chemical metal is your best bet.
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
