90 - 94 Polo late spec / optional bits & coupe roof gutter trims
Started by genesisGT, June 05, 2012, 04:54:50 PM
genesisGT
Clearing out my coupe bits as i dont have one anymore staying on the squareside...
* Coupe/squareback - First aid kit holder and mounting screws x3 ready to fit £12posted
* Late spec boot side carpets and the 4 retaining plastic clips (carpets will fit early cars but your car wont have the hole for the clip) £18 £15 posted
* uber rare coupe plastic boot sill trim in VGC needs a wipe but will come up like new. only has 2 tiny cracks as seen in close up pics, rear clips and 2 plastic rivits present £28 posted in a hugh drawing tube or cardboard box.
* Obsolite Coupe/saloon roof gutter trims, ends are good and not all split open £30 posted in drawing tubes
* Rear seatbelt guides for mounting in the rear door card recess ( your car has the hole in the bodyshell ready for these you just need to drill a 8mm & 10mm hole though your door card to fit. includes the mounting screws rear clips are all fine. 1 has a few light scuffs as seen in the photo but should improve with a wipe £10 £9 posted in a box or £8 £7 in a jiffy bag at your own risk.
* Tinted rear clusters (passengers has a crack) £22posted
* Clear front indicators, bulbs, holders with original boxes £12posted
* GT coupe wheel trims x6 all pretty good condition with minor scuffs £22 posted.
* G40 ECU wiring loom, few cut damaged wires but nothing 30mins with a soldering iron or climp and donor connector couldnt solve (ECU section only not general engine loom or headlight part) £34 posted.
* Saloon minty rear wiring loom from dash back ideal for mk2 saloon GT/G40 conversions cost me £40 so looking for my money back.
* Standard non GT/G40 boot mat VGC £12
* Home made black heavy duty boot mat (made from high street main entrance carpeted matting) £8
Please note all parts have been in storage up my loft (nice warm and dry) so appear dusty in the pics and will need a wipe/hoover over but are all in VGC unless stated.
Pics:
stu g4T
Hi
Is the plastic boot trim still available?
If so I'll take it.
Stu
TOMG40
Hi mate have you still got the gutter trims if so will defo take them of your hands. :)
SpikeyG40
Second dibs on the gutter trims if TOMG40 changes his mind!
