Starter motor
Started by Etches, September 22, 2011, 12:29:47 PM
Etches
Think mines just popped, went on holiday then came back drove the car and it was fine. Next day engine wouldnt crank, ignition primes as does the fuel pump. Shall check power to the motor on sat hopefully its that rather than something more serious. Located in sheff
grungeisdead
got a couple here mate in manc (sk10 5rx)
grungeisdead
also check your earth straps, and you can manually test the start by bridging the solenoid to the power feed and ensuring the starter is earthed
