Stalling problem cured
Started by matthg40, September 13, 2011, 03:20:04 PM
matthg40
The stalling problem I had I think I have sorted I adjusted the screw at the back of the throttle body and got it ticking over better I also cleaned the isv aswell.the one thing that still baffling me is when I take the blue temp sender plug off nothing changes now my question to you Lot is can the ecu get stuck in limp mode or service mode or what ever it's called
still means the ECU is not happy about something
but then you should give it a ten minute drive to make sure any fault codes have cleared and then try it again.
matthg40
Ok matey thank you for always helping will take it for a spin when rush hour traffic is quieter does the ecu reset it's self then
yeah it just clears the fault codes once the fault has gone away after ten minutes or so.
