Right compression ratio
Started by vwmk3jon, January 30, 2011, 11:16:55 PM
vwmk3jon
Ok, so I've finally had enough of this stupid eaton and all it's lil problems and would like abit more reliability so have decided to look into going turbo. Are the forged pistons I have (accralite) suitable for turbo use? Most likely be a K03 due to availability of parts.
cheys03
Yeah they'll be fine - I can think of at least a couple of people using them with a K03 already. It's all down to the map - something not to skimp on and worth every penny for a good one (see PPP!).
Accralites are fine Jon- both Andy, Robin and myself use them (and lots of others), with a K03 and the right cam they give a nice drivable car off boost, and the tiny K03 will pump enough to give over 200bhp, with a nice spread of torque all over.
How come you're selling the eaton, I thought it was almost there?
vwmk3jon
Sweet. Cheers guys.
Yoof - I thought it was but it still eats belts, cuts out and generally doesnt play ball at times and feels slower than a G-lader, even at full throttle!!! Most likely start with 1272 bottom end as the engines daisy fresh.
