Inlet manifold gasket re-use
Started by dub-disaster, January 24, 2011, 09:46:29 AM
Put my inlet on torqued it up, got to remove it and refit it again can I reuse the gasket I only put it on yesterday and never ran the engine with it on, just wondered as it's the metal type with the raised ridge that squashes when torqued up. Do I need a new one ?
cheys03
I've re-used one on GT management without a problem. Not sure how it would be with boost though.
I re-used one as well and it was fine. There are £5.34 + vat from VW.
grungeisdead
+1 for re-using, you should be able to visibly see what condition the gasket is in, 3 quid from gsf and ecp or just about double from veedubya
fine to reuse as long as they're not knackered.  they last ages.
Great I'll re use it I had two where I bought a head set and I used a new one last time but don't wanna keep buying new ones thanks all :)
