Full G40 Engine inc Stage 2 Supercharger, ECU, 4 Branch, Gearbox etc.
Started by Robin, October 31, 2010, 06:16:43 PM
Robin
I have had this engine as a spare in case mine decided to crap itself however i have now decided to sell it.
The engine was removed from a running car and i believe that the engine has completed 113k miles.
I am selling the whole engine and prefer not to split as its a pain selling bits and pieces.
Basically there is everything you need apart from the wiring loom. Here is a list of the parts included.
G40 1272cc bottom end with G40 Cylinder Head - recently had a genuine cambelt and water pump change.
Supercharger - Stage 2 done by Jabbasport back in 2004.
4 Branch Manifold - does not hit the foul the supercharger.
G40 ECU
Alternator
Starter Motor
HT leads
Dizzy
Lambda Probe
Genuine VW clutch – loads of life left.
Gearbox - not an ATV though.
Fuel rail and injectors.
Idle Stability Valve
Boost return pipes
Thermostat housing and rear water pipe.
Inlet manifold and G40 Throttle body
The engine will need new throttle body, inlet manifold and exhaust gaskets. Oh and an oil filter.
This is a genuine sale so no time wasters please. Any questions please feel free to pm me.
I am located in Cheshire.
£800 ono.
newt
hi there just noticed my charger was the next one done after yours!
1224 is the serial number on mine lol
can you pm me a pic of the rear of the engine from down low ?, just want to check how something lines up that i cant see from the top
many thanks
Robin
