cyclinder head g40
Started by johnfb55, October 21, 2010, 06:56:49 AM
johnfb55
Hi after a cyclinder head standred or modified? Thanks John
grayg40
i think i might have spare GT head if thats any use?
johnfb55
It's for a g40 so is that going to work??
giorgio
I have a set of new G40 valves (Sodium filled exhaust valves) for sale if you want
johnfb55
Sorry I don't know what that means (Sodium filled exhaust valves) is that just the standard size ones? If not what size are they and how much you want?
Thanks john
the head on a g40 is the same casting, but has different valves.
johnfb55
So it would work if i up the valve size? Are both in and outlet valves smailler? as what I want it for is to do some porting to up the hp with out having to take my car of the road to get the work done.
no - same size valves - but different part number (sodium filled and slightly - like 0.1mm different length)
johnfb55
Ok thanks looking to fit bigger valves than standard anyway.
