gear linkage rubbers
Started by Beckett, October 15, 2010, 08:57:13 PM
Beckett
Hello,
i have a polo gt with g40 engine, and i have the gt gear linkage repair kit from VW, and i need the rubbers for the rod that go into the gearbox end. vw dont sell these they say they are now obsolete.
can any one help me with a link and pics of one they have fitted etc so i can get one
Thanks in advance. xx
newt
all the parts are availabe! i ordered them this week,
there is a repair kit at the bottom of the stick, the red and black bit that slides on the rod and presses into the black box that holds/ houses the stick and finally the alloy bit at the end with the rubber ball fixed on it, and there is a clear plastic bush that presses into the alloy bit and sits on the 8 mm ball joint, gearbox end of the linkage
havent got any pics but im sure if someone has etka/ etos they will be able to confrm
genesisGT
yeah all the bits are available except the plastic Rectangle bit that fits between the metal housing and the body with the 2 wee foam gaskets on it (ETKA only shows 1 gasket but you need 2).
harderst bit is getting the wee pin out the shift rod where the spring and ball socket are.
