Jackson Tuning ARB Blocks
Started by Phil, March 20, 2010, 01:35:12 AM
Phil
Sure you've seen these before, if not they are designed to pull the anti roll bar forward, improves turn in and overall handling a fair bit.
Made from a slightly stiffer nylon than the Gladerseite ones (need to get the numbers) all the bolts are Zinc and the metal parts are zinc coated, so you don't have to worry about painting them.
£70 delivered.
