Altenator mounting spacer
Started by GAF2, January 25, 2010, 02:29:05 PM
GAF2
Hi guys,
can anyone supply me with the dimensions of the spacer (or even better a spare) used to mount the altenator into the engine mount, mine some how (f**k knows how) fell out along with the bolt and left my altenator bouncing of the block, been into my local VW and they said its discontinued!  am i right in saying that it is G40 specific?
cheers grant
camone
I had the same problem too. Cant remember the size of the pipe spacer, i ended up finding a thick bit of pipe and a few think washers to make a tight fit. Anything should work as long as the alternator cannot move side to side.
GAF2
yeah think i am getting to use a lathe at my brothers work this weekend so hopefully should make one out of solid bar.
cheers grant
jez1272gt
The size for the part you require
33mm in length
20mm diameter
8.5mm ID centre hole
Hope this helps!!
GAF2
cheers jez, i measured da gap at 4 oclock in da morning (nite shift) and came up with 32mm so wasnt far off.
great help cheers mate
