G40/ GT lower side skirt fixing?
Started by metz, December 14, 2009, 10:05:12 PM
metz
I was looking at the fox coupe in the garage and theres no holes in the sills to allow fixing of the lower skirt that joins behind both wheel arch trims. do you have to actually drill your own holes in the sills? there are holes in the wheel arches for the trims so why none in the sills.
Nick_S
Holes are there....just covered by stickers and underseal ;)
DKnight
if you look very carefully you will see the pattern of a circle, about 10mm
tdh-syorks
if i remember correctly, they are small square holes?? correct me if i'm wrong. i think i remember drilling them out 5mm and riveting the skirts on.
metz
Cheers guys, i will go inspect when i can get in the garage without a snow plough. damn weather.
