Brake Master Cylinderr??
Started by raf898, October 18, 2009, 10:38:37 AM
raf898
Hi I Just Done A Conversion On My 1.3 CL To A G40..
Just Wanted To Know, What's The Best Size Master Cylinder To Up-grade To Because My Braking Is A Bit Poor To Say The Least..
Cheers Guy'ss
well g40s use the same size master cylinder as the rest of mk3 polos do.  You can fit a ~20mm one from a mk2 golf 16v, passat etc... it'll reduce pedal travel but wont make your brakes better as such, in fact you'll have to press harder to get the same effort.
what brakes do you currently have on it?  As a minimum you want the 239mm vented discs like g40s do and then some decent pads.
Shailan
i changed mine to a gti 16v master cylinder, better feel now when braking
