Belts slipping!
Started by Justin14100, May 06, 2009, 04:36:05 PM
Justin14100
I know my belts are slipping a lot! So much so the squeel at 4k rpm and up, like a fan belt squeel!
Question is how much boost am I loosing you think, and are they slipping at lower rpm too? (I don't know much about belt slip!)
Working on getting some toothies, how much difference will these make?
you wont get any slip with toothies.  Tighten your belts to reduce the squeel - and get some sticky belt dressing from a motorfactors.
for a more instant fit check the belt tension, they need to be pretty bloody tight.  Also just replace them with standard ones from VW if they are worn out (shiney and/or cracked).
Justin14100
Well the problem is they are too big, had 1005mm on it now 1013! Don't know how to tension and I'm not buying new belts until I get the toothies, will I be loosing power all around the rev range or only in the squeel area? Stupid halfords not having the right size!!
DKnight
you dont know how to tension them?
No idea on what boost you are losing, how longs a piece of string
fit correct belts, only £17 or so from vw
oh and dont go to halfords, ever.
supercharged spaniel
halfrauds are terrible.....get belts from vw as mentioned.
Justin14100
The be belts are bigger, 1015mm, mine are 1013! Can Anyone quickly brief me on how to tighten?
Thanks!
remove t-peice bolts to the exhaust manifold (if fitted) (13mm head)
undo top allen bolt (10mm head)
undo side bolt - 19mm head
fit a breaker bar in the square socket on the charger mounting bracket
press towards the car
tighten 19mm head bolt
tighten 10mm allen bolt
jobs a gooden
