forged pistons?
Started by sinister polo, May 16, 2009, 11:57:29 PM
sinister polo
is it possible to get forged pistons that will fit straight in,
or do you have to go 1341?
and also whats a good brand of piston to use, keeping the standard compresion ratio?
Alexiskayak_7
Wossner pistons have the oem comp. ratio (8:1).
There is a various selection in piston bore. 75mm (stock bore-1272cc), 75,5mm, 76mm and finaly the 1341cc conv. with 77mm pistons...
Robin
price wise there won't be a massive difference between 1272 forged pistons and 1341 forged pistons so you might as well go 1341.
Alexiskayak_7
Quote from: Robin on May 17, 2009, 11:12:54 AM
Yes, it doesn't worth at all going again with 75mm pistons.. You will have to spend a little more (+ the honning process), but you'll increase the engine efficiency and reliability...
can you get 75mm bore forged pistons?  I didn't think you could. You might as well go 1341cc though as getting the block bored out by 2mm isn't expensive really.
jez1272gt
yeah pretty sure i have seen 75mm wossners listed before however might as well go 1341cc 77mm though for the small difference in cost..
Alexiskayak_7
#6
That might be useful...
