Full Blend ported G40 Charger for Sale, Recently rebuilt
Started by paulg40, November 04, 2014, 01:33:48 AM
paulg40
As the ad says, I bought this charger earlier this year as a spare whilst I rebuilt my charger on my G40 as at the time the car was my daily. Now that its no longer a daily I don't need to have the spare really as I can just rebuild as and when I need.
When I bought this charger it didn't really need a full rebuild however I chose to buy a full kit from Pete and do one anyway! as this was only on the car whilst I gave my original charger an overhaul it has only done the run in miles of 400 miles.
When I bought the charger the outlet dome threads were looking very worn and would not have lasted another torqued up bolt so I have put Heli-coils into two of the threads, this has actually made the threads a lot stronger than the original and gives you a lot more confidence to tighten up, so much so I think it should be part of any rebuild to make sure they are strong enough for the future.
Also the thread for the oil drain was feeling pretty ropey so this also took a hell-coil (which is an odd size and an expensive hell-coil!). This is now again way stronger than the original.
I have had this charger apart and have the photo's to prove if you wish to see the internals and its condition.
I am looking for £400 plus postage.
