aav turbo bits
Started by vwdubjay, April 11, 2014, 07:26:58 PM
bits
turbo
0 (0%)
aav
0 (0%)
Total Members Voted: 0
vwdubjay
Hi all I'm currently on the search for all the bits and pieces to turbo my 1.3 aav engine there's still loads of stuff I need so here's the list: - GT inlet manifold - Mk3 NZ/GT/G40 in-line fuel pump - Mk3 NZ/GT/G40 fuel rail - GT fuel pressure regulator - G40 throttlebody - G40/G60 CO pot - G40 knock sensor - G40 auxiliary air valve + hoses - NZ/GT/G40 water pipe with auxiliary air valve mount - Mk3 NZ/GT/G40 lambda sensor - G40 ECU, standard map sensor - G40 plastic boost hose with CO pot mount - G40 map sensor vacuum hose - G40 brake servo pipe with vacuum take-offs, - vw11 brakes - turbo exhaust manifold and downpipe - ko3s turbo - pp subframe stage 2 or 3 - intercooler - oil cooler I've took most of this list off the thread in the FAQ there probably is bits I've missed off but I have already got some stuff just need to check what I have got and then will update the list, no in any massive rush to get all the bits but would like it all completed by July Many thanks jay
Freddy77
I can do a lot of this list for you
I have spare
Fuel pump
fuel rail
throttlebody
co pot boost pipe
aux air valve and pipes
Servo pipe and vacuum take offs
standard intercooler if interested
located in yeovil somerset if interested pm me
Agent47
Got 2 sets of G40 brakes if you're interested?
vwdubjay
Agent47
How much do you need? Got carriers, calipers, discs, pads, disc protector plate, braided lines.
vwdubjay
I need callipers, disc projector and braided hoses, how much for that?
Agent47
Disc protectors are the one bit I didn't pick up at the weekend. Be a few weeks before im down that way again. Say 50 posted without the protectors, 55 with but it'll be a few weeks before I get them.
vwdubjay
Are the g40 ones the same as the 1 litre disc protectors?
Agent47
I would have thought so, but sure some others would be able to confirm.
vwdubjay
Haven't been on this for a while, does anyone have anything? I really need to get parts sorted
