Uprated radiator support bar
Started by vee-dub90, April 10, 2014, 06:25:07 PM
vee-dub90
I have a brand new never used support bar up for grabs as it is no longer required, it is made from 3mm thick mild steel, it has then been zinc plated for that extra protection.
They have all the holes for mounting to the chassis, holes for the radiator and the holes for the intercooler on the front.
If you have ever had an original front bracket off you will see how weak it is, this bracket strengthens the front a great deal, help stopping the dreaded chassis flex.
All in all a great addition to any mk3 polo.
Fitment is a simple task, please note these brace bars can not be fitted with the standard plastic radiator cowling, the cowling will require modification.
I can get pictures of the actual item if needed..
Looking for £35 posted or can take to Early Edition on Sunday 13th
physicsfool
vee-dub90
