Technical => Engine and Transmission => Topic started by: POLOMON on July 19, 2012, 11:11:01 am
Hi All,
As title really, ive had a search about on here and all i keep finding is the information on charger pulleys. Nothing seems to be about for the cam pulleys.
I do not have a G40 item to compare tooth profiles so thought i'd ask on here :-)
Thanks chaps,
Ben
yes they're the same.
the only difference between cam pullies is that older ones had square teeth and newer ones (most stuff J plate onwards) had round teeth. So the different teeth need different cam belts and the bottom pulley needs to match too. Most mk3 stuff will be round tooth
Thanks Hayesey, i ask as mine was a J reg you see, i knew it was a funny age for the change over so for you to say that cleared it up. As long as i have a round tooth AAU puley all is well.
Thanks alot, can sort out getting an adjustable item made now :-)
