Technical => Engine and Transmission => Topic started by: Robga on September 14, 2008, 06:20:48 pm
Hi
Has anyone on here fitted this Nology coil to their G40? http://www.nology.com/images/vwmodulekit.gif
Ive seen a G40 somewhere before using it but since fitting it myself my G40 is not starting so either the wires are different on the Polo than the Golf or the new coil is faulty.
Do i need to swap wires around as the coil and amp were ment for a Golf?
Rob
[quote pid=4112 author=H866MPR date=1221412848]Hi
Rob[/quote]
I have a Nology on mine. It is plug and play. Difficult to find a good place for the coil though
Sorry, I can't help you here Rob. I've not seen these before, I take it they're supposed to be a good upgrade? Was it expensive?
Cheers,
Richard.
do these kits cause any problems to the car after time?? how much are they?
[quote pid=4121 author=polo classic date=1221483883][quote pid=4112 author=H866MPR date=1221412848]Hi
Rob[/quote]
I have a Nology on mine. It is plug and play. Difficult to find a good place for the coil though[/quote]
I recon i've got a dud! Tried it on my Golf just to be sure and still no good. :(
I mounted it no problem in the original place using 2 sections of aluminium and the amp up on the bulkhead.
(http://img.photobucket.com/albums/v416/866rob/DSC00956.jpg)
(http://img.photobucket.com/albums/v416/866rob/DSC00957.jpg)
Does the wiring look the same as yours? Just to be sure before i send it back!
(http://img.photobucket.com/albums/v416/866rob/DSC00962.jpg)
(http://img.photobucket.com/albums/v416/866rob/DSC00970.jpg)
Breadman - Well i thought it would be a good upgrade.......if it worked! :/
Just under £100 from USA instead of £169 here!
tdh-syorks - Not sure about if they cause problems to the car but its giving me problems!
Cheers mate
Can see that mate. I just had a look on their web site for one. Might invest in one if there any good.
I've got one, never fitted it yet tho.
Im sure Dan (9OLO) has one on his car....
the original coil have a 3 wire plug, the nology have 2 wire, what to do with the 3rd wire ?
It comes with a ignition module.
If you want to use a MSD coil you will need one too. Wish id got a MSD now!
Rob
