Technical => Chassis & Braking => Topic started by: 10pin on August 06, 2010, 08:46:47 pm
ive recently bought a L reg GT that was being broken for spares so the rear axel had been sold and a standard one put in its place
i have put all new bearings, cylinders and shoes on a standard rear axel for it but when i put it in place i found that there is no where for the regulator to be attatched and as i havent seen a GT/g40 read axel so im not sure where it goes
i would like to know if its possible to just drill two holes for the valve to attatch or i need to get a proper GT/G40 rear axel any pictures or advice would be rad
cheers!
Here is how the bracket for the bias valve fits on to the G40 axle:
(http://i115.photobucket.com/albums/n311/gsbellew/G40/STP63266.jpg)
The part number for the bracket is 867 612 355
The bolts for holding it to the axle are N 010 237 6 & spring washers N 012 241 10
You may be able to drill and tap the standard axle and bolt the bracket on.
Brilliant thats exactly what i was looking for! i just stumbled on that picture and the others of your axel by chance looking through the on-going projects section.
i was talking with my dad and we thought that instead of drilling and tapping it wecould cut the head of an allen-key bolt down, weld it on and bolt the bracket down
cheers for that!
