Technical => Chassis & Braking => Topic started by: payton31 on January 26, 2009, 04:05:26 pm
hi there im looking at buying some bbs alloys until ive been told that they are off an e30
and i need to no if the centre bore will fit ?
the offset and everythin is the same and the 4x100 pcd
web back asap cheers
I'm running a set of these myself on the G and they're AOK. 6.5x14 ET 30 (some one will remember the bore size, but its fine) and I think they're RZ pattern. You'll need a set off bolts though, about ten mil. longer than original i think and courtesy of BMW as they've a straight taper.
I think that E30 has 15'' BBS RA's... But unfortunatelly only 15''...
Mine have BMW stamped on the nave plate along with all the other data !
my e30 came with 14" bbs wheels on
