Classifieds => Traders parts and services => Topic started by: oilman on June 12, 2017, 10:25:34 am
Opie Oils (http://www.opieoils.co.uk/) are pleased to announce that we are now stocking a considerable range of Amsoil (http://www.opieoils.co.uk/c-1191-amsoil.aspx) Synthetic Oil products. Whether you're looking to service your daily driver with a top quality lubricant, or taking your modified vehicle on track, and need something to offer extremely high levels of protection, then there is an Amsoil (http://www.opieoils.co.uk/c-1191-amsoil.aspx) product for you!
(https://www.opieoils.co.uk/images/upload/amsoillaunch.jpg)
For those of you that are new to Amsoil (http://www.opieoils.co.uk/c-1191-amsoil.aspx) products, they are a brand with a rich history in motorsports, and a huge name over in the States. Sponsoring massive American events such as the Grand National Cross Country, the official oil in the AMA Supercross Championship and sponsor for the International Hot Rod Association, you can see why they're trusted time and time again by motoring enthusiasts accross the world.
Amsoil was founded by Albert J. Amatuzio, a former jet fighter pilot who had conducted research on synthetic engine oils in the early 1960s. After several years of in depth study, Amsoil then formulated synthetic oils for other applications, including specialised vehicles and severe operating conditions. The breakthrough came in 1972, when they developed the worlds first fully synthetic motor oil to meet API service requirements - you can now see why they are so popular in the world of race, rally and track driving, as they were designed from the ground up to offer outstanding levels of protection, even under the harshest conditions.
Opies (http://www.opieoils.co.uk/) have an array of quality Amsoil products on the shelf and ready to go, and don't forget that you can get 10% off everything with your forum discount code! To make you aware, we are due to receive another shipment shortly that will have even more brand new products. As soon as this is with us, we will give you guys an update. Have a look below for these new products, where you will find prices, the specifications they meet and everything else you need to know:
ENGINE OILS
- Amsoil European Car Formula 5w-30 (http://www.opieoils.co.uk/p-121335-amsoil-european-car-formula-5w-30-improved-esp-synthetic-engine-oil.aspx)
- Amsoil European Car Formula 5w-40 (http://www.opieoils.co.uk/p-121336-amsoil-european-car-formula-5w-40-improved-esp-synthetic-engine-oil.aspx)
- Amsoil DOMINATOR 15w-50 Racing Oil (http://www.opieoils.co.uk/p-68954-amsoil-dominator-15w-50-racing-oil.aspx)
- Amsoil Break-In/Running-In Oil SAE 30 (http://www.opieoils.co.uk/p-121334-amsoil-break-in-oil-sae-30.aspx)
GEAR AND DIFFERENTIAL OILS
- Amsoil Manual Synchromesh Transmission Fluid (http://www.opieoils.co.uk/p-1051-amsoil-manual-synchromesh-transmission-fluid-mtf.aspx)
- Amsoil Multi-Vehicle Synthetic Automatic Transmission Fluid (http://www.opieoils.co.uk/p-1052-amsoil-multi-vehicle-synthetic-automatic-transmission-fluid-atf.aspx)
- Amsoil Synthetic SEVERE gear Oil 75w-90 (http://www.opieoils.co.uk/p-1053-amsoil-synthetic-severe-gear-oil-75w-90-svg.aspx)
- Amsoil Synthetic Manual Transmission & Transaxle Gear Lube (http://www.opieoils.co.uk/p-60092-amsoil-synthetic-manual-transmission-transaxle-gear-lube-75w-90.aspx)
FUEL TREATMENTS
- Amsoil DOMINATOR Octane Boost (http://www.opieoils.co.uk/p-121337-amsoil-dominator-octane-boost.aspx)
- Amsoil Diesel Injector Clean (http://www.opieoils.co.uk/p-121339-amsoil-diesel-injector-clean.aspx)
- Amsoil Diesel Cetane Boost (http://www.opieoils.co.uk/p-121340-amsoil-diesel-cetane-boost.aspx)
- Amsoil Performance Improver Gasoline Additive (http://www.opieoils.co.uk/p-121341-amsoil-performance-improver-gasoline-additive.aspx)
You can also find Amsoils dedicated range of motorcycle products, and even tractor oils:
- Amsoil DOMINATOR Synthetic 2-stroke Racing Oil (http://www.opieoils.co.uk/p-60173-amsoil-dominator-synthetic-2-stroke-racing-oil-tdr.aspx)
- Amsoil 20w-50 Synthetic V-Twin Motorcycle Oil (http://www.opieoils.co.uk/p-6380-amsoil-20w-50-synthetic-v-twin-motorcycle-oil-mcv.aspx)
- Amsoil 10w-40 Synthetic Motorcycle Oil (http://www.opieoils.co.uk/p-6518-amsoil-10w-40-synthetic-motorcycle-oil-mcf.aspx)
- Amsoil Motorcycle Octane Boost (http://www.opieoils.co.uk/p-121338-amsoil-motorcycle-octane-boost.aspx)
- Amsoil Synthetic Tractor Hydraulic/Transmission Oil SAE 5w-30 (http://www.opieoils.co.uk/p-73849-amsoil-synthetic-tractor-hydraulictransmission-oil-sae-5w-30.aspx)
Simply click HERE (http://www.opieoils.co.uk/c-1191-amsoil.aspx) to find everything that we stock from Amsoil so far. Amsoil products are typically very difficult to get hold of due to the fact that they are imported from the States. However, Opies (http://www.opieoils.co.uk/) will be stocking everything that we can get our hands on, so just let us know if there's anything specific that you need that isn't listed.
Every single Amsoil product is designed to offer peak performance and the highest levels of protection, allowing you to put your vehicle through its paces, while having peace of mind that your engine has a product in it that is up to the task. We'll take Amsoils Signature Series engine oils as an example of what to expect:
- 75% more engine protection against horsepower loss and wear than required by a leading industry standard
- Significantly extends the life of vital components such as pistons and cams
- 93% better piston deposit score than the leading industry standard
- Oil thickening limited to 82% below the leading industry standard
All of these results are based on independent testing of the Amsoil Signature Series 5w-30.
This range of Amsoil products is due to increase as time goes by, so we'll be sure to keep you guys in the loop as more products are added. You can keep an eye on our current offers page HERE (http://www.opieoils.co.uk/t-Current-Offer.aspx), where you will find up to date discounts, deals and clearance products.
That's it from us today, but as always if you require any oil advice then feel free to ask. You can call us on 01209 202944 Monday - Friday 8.30am - 5.30pm, send us an email to sales@opieoils.co.uk or just ask us here and we will be happy to help.
Until next time
- Oilman
