Technical => Superchargers / G-Lader => Topic started by: Ä‘uro on August 01, 2016, 10:16:57 am
Cheers guys
Placed in my Arosa G60 fresh rebuilt. pressure is only 0,5 Bar. IMHO this is 2 low isn't it ?
Charger is fully ported (intake - both sides on 72 mm + exaust part full) on top of exaust side i places "U bogen" (big pipe 180°) with diameter 76 mm. everything has been inspected and now parts has been placed in side.
Rest of the piping is only 50 mm in diameter ...
Crankshaft pully is 107 mm in diameter and G has 62 mm pulley which leed us to ratio of 1,726 . This should be ok as on Corrado pulley is 126 mm and on Passat 132 mm., the ratio is fm 1,66 till 1,9 and in that range G is working fine. everything else is 2 high or 2 low
My question is : is it possible that my crankshaft pulley is 2 small even I hv good ratio between this 2 pullyes and I can not get better pressure or can it be that my fresh rebuilt charger hv some faliure and can not produce more than 0,5 bar pressure?
tks in advance
Damjan
Small pulleys are more inclined to slip than bigger pulleys.
Which type of pulleys do you use? 6PK?
sliping is not an issue.
it won't slip. no neet to worry about it.
I hv tooths (24 tooth)
I'm just worried regarding small pressure . As Im reading pressure should be app 1,5 Bar and I hv only 0,5
is it fitted to a G60 or a G40 engine?
You are only turning the charger around 11K-12K rpm, not much more than stock, but on a G40 you should at least see 0,8 bar
Have you checked for leaks?
Cheers man
I paced G60 charger on PY G40 engine with tooth pulley 65 mm
As i could see on 3 Trpm it should be app 0,7 bar and on 6,5 trpm pressure should be app 1,5 bar.
no leeks at all . checked all 3x
Is the charger in good condition? If the scroll seals have gone bad it will not produce enough boost.
everything is new and fresh. charger has only 42 km (made today morning )
Have you checked for any leaks?
I think I hv small ratio on pulley's . As checked I hv "standard" ratio as on standard G60 charger on Corrado.
