Technical => Electrical => Topic started by: FORCEDINDUCTION on October 24, 2013, 06:43:49 pm
well,starting to put a few things together now the little G is running properly ( throttle cable not fully opening/closing BRV!) looking to pick a signal for the rev counter.......as the wiring has been tucked by previous owner I can trace certain wires to a decent place....
can I pick the signal up from the cable side of the ECU ? or from Hall sender somewhere..the neg on the coil has been cut and wrapped so don't really want to,tap into that....
also can I tap into the oil feed line section ( the tall brass looking coupling) for an oil pressure sender?
cheers peeps.. 90 % happier I've found another .6 bar boost
PIN 25 is ignition coil and ignition amplifier.
PIN 24 is tachometer. Could try one of them?
As for the oil sender, most people tend to get a t-piece and put that into the other oil sensor. Think its m10x1 thread but you will need to check.
that's the sort of reliable info I come on here for cheers Jez
