Technical => Turbochargers => Topic started by: Etches on May 13, 2013, 07:19:27 PM
Title: Dump Valve issue
Post by: Etches on May 13, 2013, 07:19:27 PM
Another issue here, wound my forge actuator rod up abit from 0.5 bar and each time i build the boost pressure up my forge 007p seems to dump even on throttle. Obvs I need to take it off and have a look , maybe change to a stiffer spring but I've had 1 bar of boost with the same valve. Has anyone had any similar problems with there Forge 007p? The vac line is on the front of the tb for reference.
Etches
Title: Re: Dump Valve issue
Post by: Andy on May 13, 2013, 07:45:05 PM
Vac feed to DV needs to be post-throttle body.
Post by: Etches on May 13, 2013, 07:47:53 PM
Ah! Stupid me haha, I used to have it on t-piece cheers man
Post by: metz on May 13, 2013, 11:06:14 PM
easy fix  :D
You at lowdown meet on monday tom?
Post by: Etches on May 14, 2013, 08:31:02 AM
Yeahman I will be, dunno wether it will be at 7 or 9 though as I have to wangle leaving work early
