I've seen this roughly explained on other threads but I still don't follow clearly.
(http://img844.imageshack.us/img844/1129/wotremoval.jpg) (http://imageshack.us/photo/my-images/844/wotremoval.jpg/)
Do I connect the brown/yellow wires to the boost switch then leave the other 'idle' switch the way it is? Or what do I do with it?
Adrian
Anyone?
Its just the full throttle switch you cut and wire into the pressure switch dude, i can get you a pic of mine if you want?
yes it is those two wires you have to switch
No need for a pic if its just those 2 wires you connect to the boost switch :) but thanks anyway.
Thanks for that guys.
Is there any specific orientation between these wires and the boost switch? I assume not...!?
you assume correctly! :)
