Technical => Chassis & Braking => Topic started by: RyanC on September 06, 2012, 08:26:58 PM
Title: brake conversion
Post by: RyanC on September 06, 2012, 08:26:58 PM
I am thinking of converting my brakes. I hav been told that it is a waste of time putting rear discs on as they are very light at the back as it is, I don't no what ppl opinion is on rear disc conversion? But Imo defo changing fronts to 256 mm :)
Title: Re: brake conversion
Post by: hayesey on September 07, 2012, 09:27:36 AM
just stick with 256mm on the front and then rebuild the drums at the back, clean them up and replace anything that needs replacing so they'll adjust up nicely.  If you fit discs at the back you'll need some kind of bias valve so it's over braked at the back.
Post by: RyanC on September 07, 2012, 11:36:22 PM
ant the bias valve ur on about also called brake pressure regulator?
