Technical => Engine and Transmission => Topic started by: tez on July 28, 2012, 11:16:35 AM
Title: First run of engine - misfiring and metallic noise?
Post by: tez on July 28, 2012, 11:16:35 AM
I finally got my G back together yesterday after the engine being out the car since Feb and having a charger rebuild. It's all running, but has a slight misfire. I'm off to pick up a new coil and leads now. It's already had a new dizzy cap and rotor arm, and the plugs are only about 5k old anyway. Any suggestions on what it could be if this doesn't clear it up?
Also, there's a metallic jangling noise every so often.
Here's a Youtube video of it, hopefully you can hear it:
http://www.youtube.com/watch?v=Kbn-6u8UalQ
Any ideas what the noise could be? It sort of sounds like the alternator pulley guides to me maybe?
Title: Re: First run of engine - misfiring and metallic noise?
Post by: scotsjohn on July 28, 2012, 02:45:21 PM
Always a worrying time, suggest you remove the charger/alternator belts first, that should help with sourcing the rattles.Sure the timings spot on?; when you're at the last stages and keen to get things up and running is the time you're most likely to slip up.
Post by: Justin14100 on July 31, 2012, 12:04:42 AM
Is it running a toothed charger belt? its worth checking that.
Post by: tez on July 31, 2012, 10:43:32 AM
Cheers guys, I tightened the guides on the charger pulley and it's a lot better now. It got an MOT last night so will be on the road again after I tax it tomorrow :D
