Club G40 => General Car Chat => Topic started by: murraycraig40 on February 29, 2012, 10:32:44 PM
Title: what is ther best intercooler for the job guys
Post by: murraycraig40 on February 29, 2012, 10:32:44 PM
just lookin for a resanable priced and that willl fit nicely in ma g cheers guys
Title: Re: what is ther best intercooler for the job guys
Post by: Max on February 29, 2012, 10:45:15 PM
I don't think anyone actually does an off the shelf solution for G40s, but there was talk of a group buy not long ago for a similar one PSD used to sell.
Post by: xandyx on February 29, 2012, 11:25:34 PM
check for a universal front mount intercooler on ebay, there are a few sizes arround 50£, check the size that fits better.
Post by: hayesey on March 01, 2012, 09:22:58 AM
PPP did have some kits in that were similar to the old PSD ones, not sure if there are any left.
Otherwise, get hold of a universal one off ebay or go scrapyard hunting, lots of TDI cars have useful intercoolers on them.  But in either of these cases it's far from a "kit" you'll need to make the mounting parts and get it working yourself.
Post by: ereeiz on March 01, 2012, 11:36:16 AM
I wrote the dimensions of the space available, with a rough idea of inlet/ outlet areas (although they can be edited with new hoses) went to a scrappy that has parts on the shelf and just worked from one end to the other, noting down ones that would fit. Then I went home and looked up the flow rates, etc for them. This was for a mk2 golf so can't reccomend anything personally. I ended up with a HUGE Merc Sprinter/ Vito IC but noticed there was a little bit of lag. In fairness I hadn't driven a G40 for a while before/ after so not sure if that was the cause/ aided the lag in any way.
Post by: Justin14100 on March 01, 2012, 11:47:28 AM
I found a universal one on eBay recently for £60 which looked great and was about the right dimensions to fit in the bumper - obviously you could go bigger if you want but a small - medium sized front mount would be the best option for a G-Lader. Try there first, then work out the pipework you need.
Post by: murraycraig40 on March 02, 2012, 05:36:55 AM
cheers guys
Post by: ctothey on March 18, 2012, 05:35:11 PM
I used a vauxhall frontera td intercooler. 35 quid.
just make sure its off a 2.3 as the 2.8 ones are too large.
it does fit but you may have to trim the front bumper a little.
cy
Post by: djtez on March 20, 2012, 07:09:21 PM
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=550+x+140+x+65
550 x 140 x 65
seems to be a size that suits, on the german ebay this size is listed under "g40 & g60"
Its just slightly bigger than the 2WD corworth cooler on mine, 40mm taller and thinner
