I bought a new set of NGK plugs off eBay for the g. I know that the correct NGK equivalent of the Bosch W4DP0 is the NGK BP7EVX.
However, I saw these on eBay and didn't notice the code was different. I think that they'll be okay, as I think the P may just stand for Platinum, but I want to be sure before I put them in. What you guys think, do they need to go back on eBay?
http://www.ebay.co.uk/itm/190638328863?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 (http://www.ebay.co.uk/itm/190638328863?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649)
Yeah im sure the P is for platinum. My new spare plugs are the same from ebay but got platinum written on the box.
I'd probably stick them back on ebay Chris, it's the platinum-ness that is the unique bit about plugs for a g40.
The seller sent me this:
(http://img.photobucket.com/albums/v57/LogIK01/Others/IMG_20691.jpg)
He also described the following to me:
"B relates to the thread diameter, P means projected insulator, 7 is the heat rating, E is the thread reach and VX means platinum"
Seems ok??
hmm not sure then. probably ok if it's a standardish g40.
Cool, cheers Hayes.
Only mod I intend to do is a reduced pulley. Not after big power, so everything else is staying stock.
I was just shitting my pants after seeing what happened to Dirt!
