UPDATED 04/16/2013
PY G40 engine block, head, cam, rocker cover, complete bottom end, Dizzy. 95k SOLD
G40 inlet manifold £20
G40 throttle body £50
G40 injectors and fuel rail £20
G40 loom with new loom tape £75
G40 exhaust manifold with snapped stud/bolt £offers
G40 plastic boost pipe and hoses £offers
G40 dials £40 SOLD
Engine Oil Cooler and sandwich plate £75 SOLD
PSD Full Blend G40 charger needs full rebuild £no longer for sale not serviceable
updated prices to sell give me offers
Updated £850ono
if you get no takers and start splitting i need a head mate or price for block and head
i have a spare g40 head just missing the cam if your interested ;D
Willing to sell the charger bracket separately if its suitable for a Eaton M45?
would you sell the box seprate? is it atv?
cheers richie
The box is an 8p box but i have an atv that needs a rebuild?
I may not sell the box with the engine as i just blown my gearbox on my 6n estate.
Updated!!! Now Breaking!!! ;D
What's wrong with the ATV? Anything broken on it?
How much inc. P&P? Cheap as chips option if poss.
Have you got the fuel pump & lines up for grabs? Don't necessarily need the lines, just a healthy pump and connection to tank really.
Ross.
pm'd
Quote from: PeteG40 on March 20, 2012, 10:26:50 AM
pm'd
pm'd back at ya
Quote from: dubstar on March 20, 2012, 10:16:25 AM
Ross.
Don't no will check mate i may of removed it for a different project then sold that project with out removing it but will check as i may have a spare?
Quote from: ereeiz on March 20, 2012, 01:31:15 AM
I have an 8p box on the g40 atm thats now going on my 6n estate as i buggered mine.
I have an atv box that will need a rebuild does not work but has no broken casing and it stopped working on me doing like 10mph as i pulled in to a road then lost drive and had a bit of a knocking noise from the gearbox so dipped the clutch and rolled in to a car park and that was that.
That would be great, thanks.
**UPDATE ON ABOVE**
Just seen CAMONE's ad for a pump set and got in first from what I can see, so I should be ok on that score now. Thanks anyway.
Ross.
Have you any pics of the oil cooler kit, and whats the condition like
Gav
Whats the loom like?
Any pictures of it?
Is it the full engine bay loom, or just the engine loom?
its just the ecu loom the most important bit and the looms mint with fresh loom tape !!! but i do have the other loom available!
bump
What's the oil cooler like buddy? Does it have a thermostatic sandwich plate??
Got other people also interested in the oil cooler mate first and not had a chance to remove it yet to check but will let every one know when i do.
No worries bud.
Hi,
How much for the bottom end only without head?
Where are you based?
Quote from: syncro on April 01, 2012, 11:49:33 PM
Hi,
Not splitting the engine its to good for that.
Update i have now fixed my daily car so have transport again and will be able to get to my unit to collect and remove parts from the g40 and get any pictures! pm me people ty
do you still have most of the bit for a full conversion?
cheers, Liam
is the full conversion still for sale?
it was never a full conversion to start with but this is whats available
PY G40 engine block, head, cam, rocker cover, complete bottom end, Dizzy. 95k £500
G40 inlet manifold £40
G40 throttle body £70
G40 injectors and fuel rail £40
G40 loom with new loom tape £100
G40 dials £40
PSD Full Blend G40 charger needs full rebuild £200
missing ecu, gearbox, co pot sender, blue and black water temp senser, spark plugs,ht leads, supercharger belts most of the parts are serviceable parts and available new accept the ecu and gearbox give me an offer if your interested?
It will cost about 300quid more to make a full conversion and then get a fresh supercharger rebuild and you will have one very solid motor i would rather not sell and just store the engine but could do with the money but im in no rush to sell i paid 1300 for this conversion back 4/5 years ago from an older guy who was building a 1400cc motor back when psd was still running.
What's the spec of the oil cooler matey?
Hi, i`m after the plastic boost pipe, and the 2 rubber ones of you have them, how much do you want inc postage
have u still got dials mate and is that £40 posted?
im still kind of new to all this supercharger melarky. Iv got a jabba stage 2 charger on mine. Would your charger be a good upgrade to mine or would there not be a great difference between the two. mine is in need of a refurb so i could get this and refurb it and just swap it over with mine. Also i presume i would need a new chip to suit it too.
Sorry to ask a stupid question but its the only way im going to learn.
Stage 2 to full blend will be a nice upgrade IMO. If you've already had a remap it will probably be ok, depends what pulley you use I suppose.
how much of an upgrade would you think it may give.
We could do with a list from standard up to whatever the chargers go up to. so you can see where your at and what you could be at if you know what i mean.
i'd say stage 2 is basically a standard charger..
full blend (stage 5) or R1 spec is all what the tuners recommend is most porting you can go safely!
words from jabba..
it would be a massive difference and capable of hitting 14psi with a 65mm pulley (about double from standard i believe)
Are all the parts for the service of the charger available, I.e Im not going to have to get some specialist bits for it. Is it just a case of new seals etc.. or is it new bearings etc...
Im just trying to get an idea of overall cost of buying this and getting the service done, over sending mine away to get the work carried out to the same spec.
Gav
Sorry guy charger not for sale i have inspected it and its not serviceable!
Still got the oil cooler? What's the spec?
Yes still got it mate not had a chance to get to my unit that often and its like 15miles away so will ty my best to fund out asap!
bump
Quote from: cheddarcheese on April 28, 2012, 07:52:48 PM
Bump
Quote from: AlexG40 on May 06, 2012, 09:11:57 AM
Bump
Ill remove the oil cooler Monday Tuesday when i go see my mate then ill get some pictures uploaded!
hi i need a piston any joy ???
thanks john
ill sell you a working engine for #400quid
PY G40 engine block, head, cam, rocker cover, complete bottom end. 95k SOLD PENDING PAYMENT AND COLLECTION
Oil cooler dude??
If your still trying to shift this engine give me a shout pal
Quote from: cheddarcheese on March 03, 2012, 09:33:22 PM
how much for the cylinder head if you have it?? valves all original? seals or guides done at any point? cheers
Head already sold sorry.
updated first post!
Did you sell the whole engine or just the head?
I had a full engine and spare head thats sold
updated prices first post!
