Technical => Electrical => Topic started by: Gilly on November 02, 2011, 01:42:38 PM
Title: Throttle sensor?
Post by: Gilly on November 02, 2011, 01:42:38 PM
Hi guys, is the white sensor connected to the throttle body the throttle position sensor? If so do you know where I could get a new one seeing as they are obsolete from vw and gsf can't match one either? Thanks
Title: Re: Throttle sensor?
Post by: Justin14100 on November 02, 2011, 02:25:28 PM
Probs a new throttle body / somebody might be breaking one (in fact i  might have a spare). Its a rare part to go though.
Post by: hayesey on November 02, 2011, 02:36:24 PM
there is no throttle position sensor.  There is an idle switch and a full throttle switch which this connector connects to.
I'd open up the cover on the end of the throttle body and check the state of the wiring.
Post by: poloandyb on January 19, 2012, 09:41:16 PM
did you find owt out gilly about replacement throttle switch..mines just packed up on my throttle body
Post by: Etches on January 19, 2012, 10:22:01 PM
Mine packed up on my old one, i couldnt even get the dam thing off so i ended up buying a new one
Post by: poloandyb on January 19, 2012, 10:49:10 PM
was it second hand mate????if not where did you source one from????.im going to luk in sheff nextweek see if they can recon it for me..fingers crossed
Post by: Etches on January 19, 2012, 10:51:28 PM
Why go anywhere other than on here for parts like that mate, ive had a few off of here
Post by: poloandyb on January 21, 2012, 09:58:41 PM
yeah pal im on with one as we speak,but iv also been told they are getting alittle thin on the ground these days
Post by: ereeiz on January 22, 2012, 12:52:15 PM
Is it just a switch? Been a while since I've looked at a TB but surely you could just get one from RSonline or maplin or the like? They normally have a code of some sort on micro switches.
