Technical => Engine and Transmission => Topic started by: DMWG40 on October 16, 2011, 04:12:03 PM
Title: what model is this gearbox for
Post by: DMWG40 on October 16, 2011, 04:12:03 PM
ok finally got around to checking out the spare gearbox i have floating around
and just wondered what models of vw seat etc it will fit and what its off
is it any good for a g40 spare ?
(http://i374.photobucket.com/albums/oo182/dmwjeep/th_53d024fb.jpg) (http://s374.photobucket.com/albums/oo182/dmwjeep/?action=view&current=53d024fb.jpg)
(http://i374.photobucket.com/albums/oo182/dmwjeep/th_3e71c553.jpg) (http://s374.photobucket.com/albums/oo182/dmwjeep/?action=view&current=3e71c553.jpg)
(http://i374.photobucket.com/albums/oo182/dmwjeep/th_bd2219ac.jpg) (http://s374.photobucket.com/albums/oo182/dmwjeep/?action=view&current=bd2219ac.jpg)
Title: Re: what model is this gearbox for
Post by: youngprodigys on October 17, 2011, 10:42:23 AM
need the part number from the top of the gearbox mate - those numbers are just the casing parts numbers.
its the one which sits under the coolant housing when its bolted to the engine
Post by: DMWG40 on October 17, 2011, 01:15:29 PM
thanks.
i will have another look but those where the only places i could find numbers
Post by: Karlos the jackyl on October 17, 2011, 06:15:53 PM
Hi Dennis, the code should be stamped on the top of the gearbox in between the two  top  bolts that connect to the block... wirebrush is your friend :)
Post by: DMWG40 on November 11, 2011, 03:48:22 PM
the only other numbers i can find look they have been scratched in
(http://i374.photobucket.com/albums/oo182/dmwjeep/G40/6ec65f67.jpg)
(http://i374.photobucket.com/albums/oo182/dmwjeep/G40/d2216015.jpg)
Post by: hayesey on November 11, 2011, 04:55:35 PM
that's the right number but I can't make it out from those pictures.  You need to give it a clean.  If it starts "ATV" then it's a G40 box.  There is another code from newer G40s (L reg ones maybe) which I can't remember, much, much less common than ATV though, they are both the same box though.
Post by: xandyx on November 11, 2011, 06:38:46 PM
Quote from: hayesey on November 11, 2011, 04:55:35 PM
later models use to have CEK code
Post by: Nick_S on November 26, 2011, 05:00:46 PM
Thats a mk4 polo or mk3 golf/vento gearbox. I can tell without seeing the obscured first part of the code, it was built in 1996 ;)
