I'm having a bit of a clear-out... All parts are located in Warwickshire, I'm about 5 mins from J12 M40 - I can arrange postage if required or possibly meet up.
Sensible offers accepted - I can only say no!
Sachs paddle clutch with OEM pressure plate. £80.
I used this on my G40 when running a G-lader on a 1341cc bottom end with BV head - had no issues with it slipping. It was originally from a 6N rally car and I got it re-sintered for £50. Only took it out because I thought this was the cause of a drivetrain rattle - but it turned out to be the gearbox instead... I'd already bought a Helix setup to replace it, so this has just sat on the shelf for a few years. There's some surface rust on the pressure plate (see pic), but this should clean up nicely.
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4497Medium.jpg)
Stage 3 PPP Prototype Subframe with TCAs and Powerflex bushes. £400.
This is the original UK-produced subframe that we prototyped on my car. It uses a standard gearbox mount as the rear hoop is clearanced to fit around this - later production versions used a new gearbox mount to ease the production process. Only removed from my car because I couldn't run it with our prototype adjustable TCAs - the TCA mount uses an M10 captive nut on the frame, and our adjustable TCAs use M13 bolts.
Please note that price includes a decent set of TCAs with Powerflex bushes.
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4492Medium.jpg)
Set of new rear brake shoes for 86C Polos. Jurid branded - subsiduary of OEM tier 1 supplier Honeywell. £10.
I bought these at the same time as a new handbrake cable for the MOT, forgetting that I'd already fitted new rear shoes the previous year...
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4496Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4495Medium.jpg)
Pair of new brake drums for 86C Polos. Vetech branded. £25.
Brand new, not taken out of packaging. Cheaper than GSF!
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4493Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4494Medium.jpg)
Set of 4 Speedlines, 14" x 6" ET38. £200 - tyres extra.
Sandblasted and powder coated satin black, not some pikey Nitromoors and rattle can "refurb". Centre caps have been rattled canned though - matt black. Only for sale because I got some Compo MOs as part of a deal on another car!
They will have the new tyres removed to go on my MOs, but I can put on a set of 185/50 R14 A539s for the buyer at extra cost. Two are 2-3mm of tread, two are 4-5mm of tread - see photos for examples.
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4488Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4489Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4491Medium.jpg)
Polo alternators, new Halfords, used Lucas. New £45. Used £15.
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4507Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4508Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4505Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4506Medium.jpg)
Grayston spring assistors - stiffen up a set of springs! New £25.
Very handy for trackdays or drag strip use when you might want to temporarily stiffen up the rear springs - or maybe if you've got scrubbing issues. They're £15 each in Halfords, and these are brand new. Bought them for Santa Pod to supplement the existing pair I'm using, but I couldn't fit both sets in!
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4509Medium.jpg)
Coil spring clamps. Pikey/temporary raising or lowering. New £15.
New and unused. Bought to lower a car at work for the Geneva Motor Show, but they cut the springs instead so I couldn't flog them these!
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4504Medium.jpg)
Hubcaps/wheel centres. £10/set.
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4501Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4502Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4503Medium.jpg)
Jetex airfilter element for Saab 9-5 Aero. £10.
Might be of use to someone?! I took it off my daily to clean and re-oil - and ended up using a standard filter element anyway to make it quieter.
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4499Medium.jpg)
(http://img.photobucket.com/albums/v467/amstrange1/For%20Sale%20Sept%202011/IMG_4500Medium.jpg)
Will ask Mike when he gets back from holiday- but fairly sure he'll have the paddle clutch.
Andy, do these wheels clear the compression struts on the subframe when on full lock or are spacers required ?
they will scrub mate et 33 e.g some 5mm spacers are needed
Quote from: dub-disaster on September 26, 2011, 03:43:59 PM
On my car with the way I had the frame set, they caught very slightly on one side - a 5mm spacer would give more than enough clearance.
How much extra would you want for the tyres?
Andy's in India with work currently, not sure if he's got internet access at the moment Rich.
Andy- Dibs on those drums too!
Yoof if you can get in contact with andy i'll have these wheel off him. Coming past his way in a couple of weeks so can pick up then. Wwill drop him a pm incase he has got internet access.
If jezzas doesn't take those rims I'd take them aswell but he's got first refusal.
I'm interested in the wheels, have you ever run them with larger calipers? I have the Willwood midilite kit coming, any idea how these perform?
I'd be interested in a wheel and subframe deal.
Mike
id take the drums if not.
Any news on wheels andy? Coming up to leamington this week/weekend so can pick them up then.
Apologies for the slow response guys, I've just got back from a trip to India with work.
Wheels provisionally sold to Jezza-7. (You have PM back!)
Drums and clutch have gone.
Subframe and other bits still available.
Would you throw the subframe in the post for 300?
Quote from: G40_Mike_ on October 11, 2011, 10:36:54 PMWould you throw the subframe in the post for 300?
I'd post the frame for £350, but without the TCAs.
Let me know if the subframe sale doesn't happen, I'm interested and can collect whenever. Still need to drop that ECU off at some point to you too ;)
PM sent andy.
