Classifieds => Wanted => Topic started by: murraycraig40 on August 21, 2011, 09:51:17 PM
Title: after a g40 engine conversion :)
Post by: murraycraig40 on August 21, 2011, 09:51:17 PM
Title: Re: after a g40 engine conversion :)
Post by: grungeisdead on August 22, 2011, 01:56:06 PM
how much are you looking for spend?
Post by: curtisg40 on August 22, 2011, 04:07:34 PM
http://www.polog40.co.uk/forum/index.php/topic,7238.0.html
there we go :)
Post by: cheddarcheese on August 23, 2011, 03:23:19 PM
i have g40 conversion but is missing some parts the ECU, and a couple of sensers leads and plugs, oil feed lines for charger about £150 of missing parts.
The engine has done less than 100k and is in good condition
the super charger is a full blend psd charger the max you can port to with small pully but will require a partial rebuild.
ill sell this at £600 pounds with out charger or £700 with charger thats a big saving as i have all the parts ADVERTISED separatly and totals to a lot more than i am asking here!
the charger alone would be a good £200-300 and with a fresh service £400+
you get everything for the converion boost pipes and intercooler, engine, loom, gearbox, supercharger accept the couple of missing bits that are not hard to find or are serviceble items that you can buy new.
Post by: grungeisdead on August 25, 2011, 12:41:11 AM
100k standard PY G40 (With Stamped Full Service History), fitted with a new continental contitech cambelt at time of fitting (3k ago)
Jabba Stage 2 G-lader Supercharger
Standard Air box & Boost Return Setup
Samco Blue Boost Hoses
Polished (Top Half) & Ported Throttle Body
Full Standard G40 Exhaust
Includes all parts for conversion, such as below
G40 ECU with Standard Chip
G40 Engine Loom
G40 Exhaust with Lambda
G40 Inlet Manifold
G40 Injectors
G40 Fuel Rail
G40 Intercooler + All hoses
G40 Intercooler hose with CO-Pot
G40 Alternator + Alternator/Charger Mount
G40 Clutch / Pressure Plate (recently replaced - sub 10k ago)
G40 Flywheel
G40 Coil
G40 Dizzy
Also comes with 65mm Pulley & Jabba custom RR'd chip (which got around 150 ATF when fitted to a previous owners car)
Can come with CEG Gearbox and thicker Mk4 driveshafts if required at no extra cost (The box was filled with Genuine VW Gearbox oil 3k ago)
Only omissions is the fuel pump interior loom and both fuel pumps.
I am after £995 for the lot, and can fit it to your car for extra (please PM to discuss your particular vehicle)
I am selling this engine from my Current Mk3 G40, the car is for sale complete for £1,995. I have purchased a 67k G40 project, which I will be donating its parts for the Grey G40, due to its low-milage, and as such, the 100k engine is surplus to requirements. I would keep it as a spare, however not including those two, I already own three PY engines.
Please email yousafn at gmail.com or text on 07950 675 910 for any further info.
Saf
(http://i16.photobucket.com/albums/b12/yousafn/G40bay.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/G40sidebay.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/G403.jpg)
