Technical => Engine and Transmission => Topic started by: Barney on August 16, 2011, 03:31:39 PM
Title: alternator pulley torque setting
Post by: Barney on August 16, 2011, 03:31:39 PM
anyone know how tight to tighten the pulley nut?
Title: Re: alternator pulley torque setting
Post by: cheys03 on August 16, 2011, 03:57:22 PM
If you're lucky, the shaft of the alternator will have an allen key hole in the pulley end, enabling you to hold the shaft (oooh errr) while you tighten the pulley. Otherwise either a chain whip on the pulley (I would only do this if the pulley is steel, use an old belt to protect the pulley), an air ratchet/impact gun, or in extreme circumstances a CAREFULLY placed screwdriver in the fan against the case of the alternator while still holding the fan by hand to reduce the load on the screwdriver. Be prepared to bend back the fan blades though if you do this.
Post by: cheys03 on August 16, 2011, 03:58:18 PM
The above advice will vary depending if the pulley has a woodruff key or not.
Post by: Jezza-7 on August 16, 2011, 08:25:18 PM
Are you after a torque setting?
Post by: cheys03 on August 16, 2011, 08:28:24 PM
Looks like he may be after a re-read. 'doh
Post by: Jezza-7 on August 16, 2011, 09:38:46 PM
Yeah me too, well the torque is 20nm if your wondering. Should be able to do that while holding the pulley.
Post by: Barney on August 16, 2011, 11:45:50 PM
cheers for that.  The hardest part was getting the alternator back in its bracket.
