Technical => Chassis & Braking => Topic started by: Jake G 4 0 on August 10, 2011, 11:20:08 AM
Title: Willwood brakes
Post by: Jake G 4 0 on August 10, 2011, 11:20:08 AM
Hi lads,
I was looking into willwood brakes and I was wondering how easy it is to switch over??
So anyone who has done the conversion could tell me,
Can you run 239mm discs?
Do they bolt straight on or do you need a bracket/adapter?
Is there anywhere where you can buy a whole kit??
Thanks Jake.
Title: Re: Willwood brakes
Post by: hayesey on August 10, 2011, 11:39:38 AM
answers in the same order as questions:
- with the correct carriers you'll be able to but I'm not sure where you'll get them from.  If you are wanting to do this to keep 13" then I'm not sure it'll be possible anyway as the calipers are very large
- you need a carrier/bracket
- RallyDesign, it's for a mk1 golf gti but they had the same brakes as a g40
It's a relatively easy swap, you do need to grind a small amount of metal off either the bracket or the bearing carrier or else they foul.  Then you need to do something about the brake lines as polo ones arent long enough.  I just made up some small adaptors with some solid brake line and a bracket.  Or if you are going to get new flexi hoses then just get some longer golf ones.
Post by: Yoof on August 10, 2011, 06:12:03 PM
From some rough calcs and measurements I've done, the smaller diameter discs if anything causes more of a headache with the centre of the rim catching.
13" rim will fit a 256mm wilwood caliper/carrier if it's the correct offset, which I think is in the region of ET0...  >:(
I want to go to 13" for track, as tyres are alot cheaper, and slicks are readily available  :)
Post by: Max on August 10, 2011, 07:21:04 PM
Reckon a kit like this would give more clearance on 13" wheels?
http://www.rallydesign.co.uk/product_info.php?cPath=562_563_565&products_id=3914
Post by: Jake G 4 0 on August 10, 2011, 07:40:04 PM
Thanks for the advice lads,
I have got 14's on so will I be able to run 256mm without the use of spacer's??
I was only wondering about using 239mm is because I have just bought a decent set of grooved/drilled discs.
Also i have braided flexible hoses so they should reach the calipers hopefully.
I'm guessing the bracket comes with the kit as well?
Those 13's are going to look very full yoof  :) but surely you are going to get serious wheel spinning with 13's even with a lsd??
Post by: Yoof on August 10, 2011, 08:25:32 PM
Not with sticky rubber  :) Although I imagine it will still spin!
Post by: Jake G 4 0 on August 11, 2011, 08:21:41 AM
Super sticky rubber may help..  But still let us know how it goes when you get round to running this setup. Should be fun with the amount of power your running  :)
Post by: hayesey on August 11, 2011, 09:32:34 AM
QuoteI have got 14's on so will I be able to run 256mm without the use of spacer's??
it depends on the inner shape of the wheels and the offset of the wheels but it is highly unlikely.
Post by: youngprodigys on August 11, 2011, 02:29:22 PM
ive got a few sets of wilwood calipers in boxes at home. which ones were you looking at? ive dynalite 1052 and 1056 i think. no carriers tho.
Post by: Etches on August 11, 2011, 02:44:51 PM
How big spacers are we talking hayesey? 10 or 15mm?
Post by: hayesey on August 11, 2011, 03:12:01 PM
well it's going to be different for every different wheel but my 14" require at least 8mm ones.  The kit from RD came with some 6mm spacers which I just use on the back.  I've got 10mm on the front now because they were the smallest I could find at the time which are hub centric.
