Technical => Engine and Transmission => Topic started by: boyzey on August 05, 2011, 04:52:50 PM
Title: g40 pistons ?
Post by: boyzey on August 05, 2011, 04:52:50 PM
oryt people just after identifiying a set of pistons am hoping they are g40 ones  :), do they have a specific part number or is it a case of putting them side by side with gt pistons, any help wuld be great cheers
Title: Re: g40 pistons ?
Post by: boyzey on August 10, 2011, 09:34:53 PM
any help please or even ideas
Post by: Jezza-7 on August 10, 2011, 09:36:37 PM
I got some laying around. Give me a number and photo if you can. Will check tomorrow.
Post by: boyzey on August 13, 2011, 08:05:18 PM
havent got the pistons wiv me at mo mate, but if ther is any numbers on urs it would be much apriciated if you could send them on and i can check with myn wen im next down with them, do you recon you could tell difference just looking at them then m8
thanx for reply
Post by: Jezza-7 on August 13, 2011, 08:20:57 PM
Er i dont know. I believe all mk3 polo con rods are the same, except the 1w ones as they have a longer stroke. So maybe all 1292cc pistons are the same?
Post by: youngprodigys on August 13, 2011, 10:10:47 PM
all the same except for 1w which have a larger 20mm pin
Post by: willsalter1000 on August 14, 2011, 10:05:03 AM
Quote from: youngprodigys on August 13, 2011, 10:10:47 PM
1w engines have a 22mm pin, all others are 20mm
Post by: boyzey on August 16, 2011, 09:44:54 PM
oryt thanx for all replys so basicaly as far as i was aware all con rods are defo same, no that some 1 on hear sed that crank shafts could possibly be ever so slightly different but so small you wouldnt notice, and i thought that pistons wer specific to g40 for compression  ???
Post by: PeteG40 on August 16, 2011, 09:49:20 PM
pistons are specific, conrods same. crankshafts are different, (dif part no)
Post by: boyzey on August 16, 2011, 09:53:42 PM
oryt pete thought pistons were the differance ye cheers for that you dont no how to identify g40 pistons from say gt ones do you i got a set and wana no wat they are cheers
Post by: Daryl on August 16, 2011, 10:25:21 PM
G40 pistons dont have groves cut out 3f, aav etc do
