Was just wondering if the pipe that connects to the breather pods outlet pipe is definately 1" in diameter? couldnt find any in b&q...
Do you need to cable tie it in place or wil the pipe be on tight enough?
yep thats the correct size. I used a jubilee clip.
Quote from: Jezza-7 on July 23, 2011, 03:36:48 PM
Jubilee clip is a much better idea than a tie wrap, means you can adjust / remove is necessary.
oh right, cheers. jubilee would be better ;)
